Speed test for parallel processing
0.0.1 How fast is fast?
Let’s see how quickly some predictive model runs, in order to estimate time consumption for larger machine learning pipelines. In addtion, let’s see how much time is saves when using multiples cores, ie. when parallel processing is enabled.
Let’s use a Ranger (Random Forest) as learner.
0.0.2 Tidymodels pipeline
Let’s copy this template in order to not have to type all the verbose Tidymodels code.
0.0.3 Setup
# Setup:
library(tidymodels)
library(tidyverse)
library(tictoc)  # Zeitmessung
# Data:
d <- palmerpenguins::penguins |> na.omit()
set.seed(42)
d_split <- initial_split(d)
d_train <- training(d_split)
d_test <- testing(d_split)
0.0.4 Simple Fit
# model:
mod1 <-
  rand_forest(mode = "regression")
# cv:
set.seed(42)
rsmpl <- vfold_cv(d_train)
# recipe:
rec1 <-
  recipe(body_mass_g ~  ., data = d_train) |>
  step_dummy(all_nominal_predictors()) |>
  step_normalize(all_predictors())
# workflow:
wf1 <-
  workflow() %>%
  add_model(mod1) %>%
  add_recipe(rec1)
# fitting:
tic()
wf1_fit <-
  wf1 %>%
  fit(data = d_train)
toc()
#> 0.224 sec elapsed
0.0.5 Resampling
10 times CV
# fitting:
tic()
wf1_fit <-
  wf1 %>%
  fit_resamples(resamples = rsmpl,
                control = control_grid(verbose = TRUE))
toc()
#> 2.372 sec elapsed
0.0.6 Tuning
10 tuning parameters, 10 times CV
# model:
mod_tune <-
  rand_forest(mode = "regression",
              mtry = tune())
# cv:
set.seed(42)
# recipe:
rec1 <-
# workflow:
wf_tune <-
  workflow() %>%
  add_model(mod_tune) %>%
  add_recipe(rec1)
# fitting:
tic()
wf_tune_fit <-
  wf_tune %>%
  tune_grid(
    resamples = rsmpl,
    grid = 10,
    control = control_grid(verbose = FALSE))
toc()
#> 12.419 sec elapsed
0.0.7 More tuning params
# model:
mod_tune <-
              mtry = tune())
# cv:
set.seed(42)
# recipe:
rec1 <-
# workflow:
wf_tune <-
  workflow() %>%
  add_recipe(rec1)
# fitting:
tic()
wf_tune_fit <-
  wf_tune %>%
  tune_grid(
    resamples = rsmpl,
    grid = 1e2,
toc()
#> 16.143 sec elapsed
0.0.8 Parallel processing
tic()
wf_parallel_fit <-
  wf_tune %>%
  tune_grid(
    resamples = rsmpl,
    grid = 1e2,
      verbose = FALSE,
      allow_par = TRUE))
toc()
#> 16.46 sec elapsed
0.0.9 Parallel processing - explicitly
library(doParallel)
# Set up a parallel backend with multiple cores
cl <- makeCluster(3)  # 4 cores, adjust as needed
registerDoParallel(cl)
tic()
wf_parallel_fit <-
  wf_tune %>%
  tune_grid(
    resamples = rsmpl,
    grid = 1e2,
      verbose = FALSE,
      allow_par = TRUE))
toc()
#> 20.697 sec elapsed
Again, a drop in computation time. Interesting.
0.0.10 ANOVA race
Can we get a speed-up using an ANOVA race?
library(finetune)
tic()
wf_race_fit <-
  wf_tune %>%
  tune_race_anova(
    resamples = rsmpl,
    grid = 1e2,
    control = control_race(
      verbose = FALSE,
      allow_par = TRUE))
toc()
#> 9.303 sec elapsed
Not really. At least not in this case.
However, the authors report a benchmark with a juicy speed-up.
0.0.11 Acknowledgements
0.0.12 Reproducibility
#> ─ Session info ───────────────────────────────────────────────────────────────────────────────────────────────────────
#>  setting  value
#>  version  R version 4.2.1 (2022-06-23)
#>  os       macOS Big Sur ... 10.16
#>  system   x86_64, darwin17.0
#>  ui       X11
#>  language (EN)
#>  collate  en_US.UTF-8
#>  ctype    en_US.UTF-8
#>  tz       Europe/Berlin
#>  date     2023-11-15
#>  pandoc   3.1.1 @ /Applications/RStudio.app/Contents/Resources/app/quarto/bin/tools/ (via rmarkdown)
#> ─ Packages ───────────────────────────────────────────────────────────────────────────────────────────────────────────
#>  package        * version    date (UTC) lib source
#>  backports        1.4.1      2021-12-13 [1] CRAN (R 4.2.0)
#>  blogdown         1.18       2023-06-19 [1] CRAN (R 4.2.0)
#>  bookdown         0.36       2023-10-16 [1] CRAN (R 4.2.0)
#>  boot             1.3-28.1   2022-11-22 [1] CRAN (R 4.2.0)
#>  broom          * 1.0.5      2023-06-09 [1] CRAN (R 4.2.0)
#>  bslib            0.5.1      2023-08-11 [1] CRAN (R 4.2.0)
#>  cachem           1.0.8      2023-05-01 [1] CRAN (R 4.2.0)
#>  callr            3.7.3      2022-11-02 [1] CRAN (R 4.2.0)
#>  class            7.3-22     2023-05-03 [1] CRAN (R 4.2.0)
#>  cli              3.6.1      2023-03-23 [1] CRAN (R 4.2.0)
#>  codetools        0.2-19     2023-02-01 [1] CRAN (R 4.2.0)
#>  colorout       * 1.3-0      2023-11-08 [1] Github (jalvesaq/colorout@8384882)
#>  colorspace       2.1-0      2023-01-23 [1] CRAN (R 4.2.0)
#>  crayon           1.5.2      2022-09-29 [1] CRAN (R 4.2.1)
#>  data.table       1.14.8     2023-02-17 [1] CRAN (R 4.2.0)
#>  devtools         2.4.5      2022-10-11 [1] CRAN (R 4.2.1)
#>  dials          * 1.2.0      2023-04-03 [1] CRAN (R 4.2.0)
#>  DiceDesign       1.9        2021-02-13 [1] CRAN (R 4.2.0)
#>  digest           0.6.33     2023-07-07 [1] CRAN (R 4.2.0)
#>  doParallel     * 1.0.17     2022-02-07 [1] CRAN (R 4.2.0)
#>  dplyr          * 1.1.3      2023-09-03 [1] CRAN (R 4.2.0)
#>  ellipsis         0.3.2      2021-04-29 [1] CRAN (R 4.2.0)
#>  evaluate         0.21       2023-05-05 [1] CRAN (R 4.2.0)
#>  fansi            1.0.5      2023-10-08 [1] CRAN (R 4.2.0)
#>  fastmap          1.1.1      2023-02-24 [1] CRAN (R 4.2.0)
#>  finetune       * 1.1.0      2023-04-19 [1] CRAN (R 4.2.0)
#>  forcats        * 1.0.0      2023-01-29 [1] CRAN (R 4.2.0)
#>  foreach        * 1.5.2      2022-02-02 [1] CRAN (R 4.2.0)
#>  fs               1.6.3      2023-07-20 [1] CRAN (R 4.2.0)
#>  furrr            0.3.1      2022-08-15 [1] CRAN (R 4.2.0)
#>  future           1.33.0     2023-07-01 [1] CRAN (R 4.2.0)
#>  future.apply     1.11.0     2023-05-21 [1] CRAN (R 4.2.0)
#>  generics         0.1.3      2022-07-05 [1] CRAN (R 4.2.0)
#>  ggplot2        * 3.4.4      2023-10-12 [1] CRAN (R 4.2.0)
#>  globals          0.16.2     2022-11-21 [1] CRAN (R 4.2.0)
#>  glue             1.6.2      2022-02-24 [1] CRAN (R 4.2.0)
#>  gower            1.0.1      2022-12-22 [1] CRAN (R 4.2.0)
#>  GPfit            1.0-8      2019-02-08 [1] CRAN (R 4.2.0)
#>  gtable           0.3.4      2023-08-21 [1] CRAN (R 4.2.0)
#>  hardhat          1.3.0      2023-03-30 [1] CRAN (R 4.2.0)
#>  hms              1.1.3      2023-03-21 [1] CRAN (R 4.2.0)
#>  htmltools        0.5.6.1    2023-10-06 [1] CRAN (R 4.2.0)
#>  htmlwidgets      1.6.2      2023-03-17 [1] CRAN (R 4.2.0)
#>  httpuv           1.6.11     2023-05-11 [1] CRAN (R 4.2.0)
#>  infer          * 1.0.5      2023-09-06 [1] CRAN (R 4.2.0)
#>  ipred            0.9-14     2023-03-09 [1] CRAN (R 4.2.0)
#>  iterators      * 1.0.14     2022-02-05 [1] CRAN (R 4.2.0)
#>  jquerylib        0.1.4      2021-04-26 [1] CRAN (R 4.2.0)
#>  jsonlite         1.8.7      2023-06-29 [1] CRAN (R 4.2.0)
#>  knitr            1.45       2023-10-30 [1] CRAN (R 4.2.1)
#>  later            1.3.1      2023-05-02 [1] CRAN (R 4.2.0)
#>  lattice          0.21-8     2023-04-05 [1] CRAN (R 4.2.0)
#>  lava             1.7.2.1    2023-02-27 [1] CRAN (R 4.2.0)
#>  lhs              1.1.6      2022-12-17 [1] CRAN (R 4.2.0)
#>  lifecycle        1.0.3      2022-10-07 [1] CRAN (R 4.2.0)
#>  listenv          0.9.0      2022-12-16 [1] CRAN (R 4.2.0)
#>  lme4             1.1-34     2023-07-04 [1] CRAN (R 4.2.0)
#>  lubridate      * 1.9.3      2023-09-27 [1] CRAN (R 4.2.0)
#>  magrittr         2.0.3      2022-03-30 [1] CRAN (R 4.2.0)
#>  MASS             7.3-60     2023-05-04 [1] CRAN (R 4.2.0)
#>  Matrix           1.5-4.1    2023-05-18 [1] CRAN (R 4.2.0)
#>  memoise          2.0.1      2021-11-26 [1] CRAN (R 4.2.0)
#>  mime             0.12       2021-09-28 [1] CRAN (R 4.2.0)
#>  miniUI           0.1.1.1    2018-05-18 [1] CRAN (R 4.2.0)
#>  minqa            1.2.5      2022-10-19 [1] CRAN (R 4.2.1)
#>  modeldata      * 1.2.0      2023-08-09 [1] CRAN (R 4.2.0)
#>  munsell          0.5.0      2018-06-12 [1] CRAN (R 4.2.0)
#>  nlme             3.1-162    2023-01-31 [1] CRAN (R 4.2.0)
#>  nloptr           2.0.3      2022-05-26 [1] CRAN (R 4.2.0)
#>  nnet             7.3-19     2023-05-03 [1] CRAN (R 4.2.0)
#>  palmerpenguins   0.1.1      2022-08-15 [1] CRAN (R 4.2.0)
#>  parallelly       1.36.0     2023-05-26 [1] CRAN (R 4.2.0)
#>  parsnip        * 1.1.1      2023-08-17 [1] CRAN (R 4.2.0)
#>  pillar           1.9.0      2023-03-22 [1] CRAN (R 4.2.0)
#>  pkgbuild         1.4.0      2022-11-27 [1] CRAN (R 4.2.0)
#>  pkgconfig        2.0.3      2019-09-22 [1] CRAN (R 4.2.0)
#>  pkgload          1.3.2.1    2023-07-08 [1] CRAN (R 4.2.0)
#>  prettyunits      1.1.1      2020-01-24 [1] CRAN (R 4.2.0)
#>  processx         3.8.2      2023-06-30 [1] CRAN (R 4.2.0)
#>  prodlim          2023.03.31 2023-04-02 [1] CRAN (R 4.2.0)
#>  profvis          0.3.8      2023-05-02 [1] CRAN (R 4.2.0)
#>  promises         1.2.1      2023-08-10 [1] CRAN (R 4.2.0)
#>  ps               1.7.5      2023-04-18 [1] CRAN (R 4.2.0)
#>  purrr          * 1.0.2      2023-08-10 [1] CRAN (R 4.2.0)
#>  R6               2.5.1      2021-08-19 [1] CRAN (R 4.2.0)
#>  ranger         * 0.15.1     2023-04-03 [1] CRAN (R 4.2.0)
#>  Rcpp             1.0.11     2023-07-06 [1] CRAN (R 4.2.0)
#>  readr          * 2.1.4      2023-02-10 [1] CRAN (R 4.2.0)
#>  recipes        * 1.0.8      2023-08-25 [1] CRAN (R 4.2.0)
#>  remotes          2.4.2.1    2023-07-18 [1] CRAN (R 4.2.0)
#>  rlang            1.1.1      2023-04-28 [1] CRAN (R 4.2.0)
#>  rmarkdown        2.25       2023-09-18 [1] CRAN (R 4.2.0)
#>  rpart            4.1.19     2022-10-21 [1] CRAN (R 4.2.0)
#>  rsample        * 1.2.0      2023-08-23 [1] CRAN (R 4.2.0)
#>  rstudioapi       0.15.0     2023-07-07 [1] CRAN (R 4.2.0)
#>  sass             0.4.7      2023-07-15 [1] CRAN (R 4.2.0)
#>  scales         * 1.2.1      2022-08-20 [1] CRAN (R 4.2.0)
#>  sessioninfo      1.2.2      2021-12-06 [1] CRAN (R 4.2.0)
#>  shiny            1.7.5      2023-08-12 [1] CRAN (R 4.2.0)
#>  stringi          1.7.12     2023-01-11 [1] CRAN (R 4.2.0)
#>  stringr        * 1.5.0      2022-12-02 [1] CRAN (R 4.2.0)
#>  survival         3.5-5      2023-03-12 [1] CRAN (R 4.2.0)
#>  tibble         * 3.2.1      2023-03-20 [1] CRAN (R 4.2.0)
#>  tictoc         * 1.2        2023-04-23 [1] CRAN (R 4.2.0)
#>  tidymodels     * 1.1.1      2023-08-24 [1] CRAN (R 4.2.0)
#>  tidyr          * 1.3.0      2023-01-24 [1] CRAN (R 4.2.0)
#>  tidyselect       1.2.0      2022-10-10 [1] CRAN (R 4.2.0)
#>  tidyverse      * 2.0.0      2023-02-22 [1] CRAN (R 4.2.0)
#>  timechange       0.2.0      2023-01-11 [1] CRAN (R 4.2.0)
#>  timeDate         4022.108   2023-01-07 [1] CRAN (R 4.2.0)
#>  tune           * 1.1.2      2023-08-23 [1] CRAN (R 4.2.0)
#>  tzdb             0.4.0      2023-05-12 [1] CRAN (R 4.2.0)
#>  urlchecker       1.0.1      2021-11-30 [1] CRAN (R 4.2.0)
#>  usethis          2.2.2      2023-07-06 [1] CRAN (R 4.2.0)
#>  utf8             1.2.3      2023-01-31 [1] CRAN (R 4.2.0)
#>  vctrs            0.6.4      2023-10-12 [1] CRAN (R 4.2.0)
#>  withr            2.5.2      2023-10-30 [1] CRAN (R 4.2.1)
#>  workflows      * 1.1.3      2023-02-22 [1] CRAN (R 4.2.0)
#>  workflowsets   * 1.0.1      2023-04-06 [1] CRAN (R 4.2.0)
#>  xfun             0.40       2023-08-09 [1] CRAN (R 4.2.0)
#>  xtable           1.8-4      2019-04-21 [1] CRAN (R 4.2.0)
#>  yaml             2.3.7      2023-01-23 [1] CRAN (R 4.2.0)
#>  yardstick      * 1.2.0      2023-04-21 [1] CRAN (R 4.2.0)
#>  [1] /Users/sebastiansaueruser/Rlibs
#>  [2] /Library/Frameworks/R.framework/Versions/4.2/Resources/library
